Threads: 81
Anyone know where I could get these cheap in UK?? I don't need those with the DMC plastic handle, a standard metal key that will fit the D will be fine.
The old one I got got bent.... now it's bent back to the right shape, but in danger of breaking inside the ignition if I continue to use it.
Kind Regards,
John [DOC No. 8]
Threads: 26
I brought my key into my local locksmith and he had a blank on the shelf.
I am sure any "decent" locksmith on the highstreet will be able to do this.
Cost me £5 for the blank and the cutting.
Alistair McCann
Northern Ireland
1981 Delorean #Vin Pilot 25
1989 Renault Alpine GTA Atmo.
I think they are from a montego/ rover based car.
Threads: 73
How comes my car has only one key, bit strange that :?
TT
Threads: 2
Rover SD1 has the same steering colum and lock.
Regards Paul O'Malley
DOC 253 South of Ireland Rep
Threads: 81
Thanks for the reply guys!
So if I get a key blank for the Rover SD1... it will be a direct replacement key blank?
Kind Regards,
John [DOC No. 8]
