28 Jul 2006, 19:53
		Hi everyone
I wanted to replace the rear speakers on my car as they where shot but did not fancy ripping off the plastic cover as I have heard that its a nightmare.
I wanted a way of getting a new set in that did not involve taking this panel off and also did not mean cutting any holes in the car.
If you take off the two wooden boards that cover the fuse box and the engine ECU you can feel under the panel that covers the rear speakers. You can feel speaker wire and if you want to you can pull this wire on both sides and it will pop of the speaker and you can then feed the wire out from under the cover. I managed to pull out about 4 feet of the stuff from both sides!!
This gave me with two options.
1.) make a new rear bulkhead board that I could mount a set of speakers.
2.) make something totaly different.
I went with the later option of making something totaly different and this is what I did.
I bought a pieced of MDF and using the piece of carpet that covers the rear deck as a template I cut the wood to this shape. I bought a 10cm hole cutter and cut two holes in it. I then bought a length of dark grey acoustic carpet and stuck it to the wood and stapled it at the back.
I bought a set of 10cm Kenwood 100watt speakers and mounted them in the two holes I had cut.
Now I suppose you are thinking that the board I have cut is now going to lie flat on the rear parcel shelf and the speakers are going to lift it up so that it sites above the lip, I knew this would happen and purposly made the board 1.5" longer than the old carpet was, this way when I put the board in the car it stuck about 3" up from the base of the parcel shelf giving the speakers loads of room and directing the sound more at the back of the drivers head. This also meant that the rear shelf can still be used to store stuff.
The shelf works perfectly and the board hides the speaker wire underneath and I can remove the board at anytime and return the car to stock. I will take some pictures of the board and you can see for yourself that it was a cheap and easy way of getting some decent sound in the car.
Alistair McCann
Northern Ireland
1981 Delorean #Vin Pilot 25
1989 Renault Alpine GTA Atmo.
Northern Ireland
![[Image: P7290065.jpg]](http://i67.photobucket.com/albums/h292/pilot25dmc/P7290065.jpg)
![[Image: P7290067.jpg]](http://i67.photobucket.com/albums/h292/pilot25dmc/P7290067.jpg)
![[Image: Afbeelding013.jpg]](http://i112.photobucket.com/albums/n189/bozzzydmc/Afbeelding013.jpg)
![[Image: Afbeelding012.jpg]](http://i112.photobucket.com/albums/n189/bozzzydmc/Afbeelding012.jpg)
![[Image: Afbeelding011.jpg]](http://i112.photobucket.com/albums/n189/bozzzydmc/Afbeelding011.jpg)
![[Image: Afbeelding010.jpg]](http://i112.photobucket.com/albums/n189/bozzzydmc/Afbeelding010.jpg)
![[Image: Afbeelding009.jpg]](http://i112.photobucket.com/albums/n189/bozzzydmc/Afbeelding009.jpg)
![[Image: Afbeelding008.jpg]](http://i112.photobucket.com/albums/n189/bozzzydmc/Afbeelding008.jpg)
![[Image: Afbeelding005.jpg]](http://i112.photobucket.com/albums/n189/bozzzydmc/Afbeelding005.jpg)
![[Image: Afbeelding002.jpg]](http://i112.photobucket.com/albums/n189/bozzzydmc/Afbeelding002.jpg)
![[Image: Afbeelding001.jpg]](http://i112.photobucket.com/albums/n189/bozzzydmc/Afbeelding001.jpg)
