Alternator equivalence
Just a theoretical question (maybe...)
Does anybody know if the alternator is interchangeable with the Volvo/ Renault units from the equivalent PRV engines? I don't need one at present, but I'm thinking that if, for example I happened to know of a decent used one going spare, would it be worth me having it, even if it were as a standby unit just in case? Or are they compeletly different in terms of fit, terminal connections, output etc etc.
Thanks all,
i used to have a paris-rhone one on my car originally rated at 95 amps.
tourettes tony has this now so ask him for a cross reference.
i have got one of those special t auto high current jobbies on.
nickt.
(salesman's hat on) We do a direct replacement for £159 which is normally a £360 unit, made by Valeo and 110A capable and a direct install for anyone replacing a ducellier (same plug). Easy to adapt to a Motorola type.
[quote="NickT"]i used to have a paris-rhone one on my car originally rated at 95 amps.
I had a renault one on mine which was slightly bigger and i couln,t fit a standard belt on it as it wouldnt go back far enough best to get the correct one i went through 5 belts on mine till Nick sent me his lovely geezer :lol: cheers TT
Standard belt fits our alt no problems.
