Threads: 18
Hello,
I dont suppose anyone knows the ID's of the hoses I have arrowed in the diagram below??
While the gearbox is out, it would definately be a good idea to change these. They are well past their best on VIN814!!
[ATTACHMENT NOT FOUND]
Any idea, or do I have to measure them?? Easier said than done with a car 450 miles away...!
Cheers, it was just on the offchance...
andy
1: 8mm
9: 16mm (5/8")
11: 16mm one end, 20mm the other.
Threads: 18
Top man, thank you! I had other answers on other forums, but no-one had mentioned that no. 11 has two different diameters. Tho Ed's site shows only a single diameter hose...
I take it no 3 is also 5/8"? From other forums I've got 5/8 or a measured 15mm...
andy
Yes, and I made one mistake - it's 19mm (3/4") not 20, it's just that the hose I bought last had 20mm ID
You can just use 19mm and that may well be what some suppliers now sell, but the original was a formed hose
Threads: 18
Thanks Martin,
So, to be clear, (and in new money)
1. 8mm
3. 16mm
9. 16mm
11. 16mm going up to 19mm ??
stunned_monkey Wrote:You can just use 19mm and that may well be what some suppliers now sell, but the original was a formed hose
Do you mean 19mm for the whole length?? Or are we still talking about one end being reduced to 16mm ??
Thanks a lot,
a
You can use a 19mm hose for the whole length but it'll be a bit squashed at the 16mm end.
Threads: 18
OK, thanks!
I thik I'll buy a reducer and both 16mm and 19mm hoses. OCD, I know....! :roll:
a
