Heater Hose ID? - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 7 - Heating / Air Conditioning (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=20) +--- Thread: Heater Hose ID? (/showthread.php?tid=4378) |
Heater Hose ID? - andyd - 18 Mar 2014 Hello, I dont suppose anyone knows the ID's of the hoses I have arrowed in the diagram below?? While the gearbox is out, it would definately be a good idea to change these. They are well past their best on VIN814!! [ATTACHMENT NOT FOUND] Any idea, or do I have to measure them?? Easier said than done with a car 450 miles away...! Cheers, it was just on the offchance... andy Re: Heater Hose ID? - stunned_monkey - 19 Mar 2014 1: 8mm 9: 16mm (5/8") 11: 16mm one end, 20mm the other. Re: Heater Hose ID? - andyd - 19 Mar 2014 Top man, thank you! I had other answers on other forums, but no-one had mentioned that no. 11 has two different diameters. Tho Ed's site shows only a single diameter hose... I take it no 3 is also 5/8"? From other forums I've got 5/8 or a measured 15mm... Cheers andy Re: Heater Hose ID? - stunned_monkey - 19 Mar 2014 Yes, and I made one mistake - it's 19mm (3/4") not 20, it's just that the hose I bought last had 20mm ID You can just use 19mm and that may well be what some suppliers now sell, but the original was a formed hose Re: Heater Hose ID? - andyd - 20 Mar 2014 Thanks Martin, So, to be clear, (and in new money) 1. 8mm 3. 16mm 9. 16mm 11. 16mm going up to 19mm ?? stunned_monkey Wrote:You can just use 19mm and that may well be what some suppliers now sell, but the original was a formed hose Do you mean 19mm for the whole length?? Or are we still talking about one end being reduced to 16mm ?? Thanks a lot, a Re: Heater Hose ID? - stunned_monkey - 20 Mar 2014 You can use a 19mm hose for the whole length but it'll be a bit squashed at the 16mm end. Re: Heater Hose ID? - andyd - 20 Mar 2014 OK, thanks! I thik I'll buy a reducer and both 16mm and 19mm hoses. OCD, I know....! :roll: a |
