is there a parts cross ref for the aircon belt?
Hi
i know it must be here somewhere, but its about time i tried to power up the aircon.
does anyone know a reference?.
thankyou
It's on here Steve if you've got a motoquip stockist close by....
http://www.deloreans.co.uk/forum/viewtopic.php?t=735
Or try this....
http://stits.org/DMCVEGAS%20DMC%20Archi ... X-Over.HTM
The Correct sized Aircon belt is 10mm x 1350mm
Gates 6234MC
that's good to know Chris, mine started smoking last year when one of my AC pulleys
seized - luckily I was able to cut the belt off, and at some point in this millennia I will
get around to changing the pulleys and the belt Smile
Chris Hawes Wrote:The Correct sized Aircon belt is 10mm x 1350mm
No it isn't because the correct belt is 12mm or 1/2" wide.
10mm belts work for a short while but they "bottom out" on the pulley and start squeaking.
right........ glad I havent rushed out to buy one then! lol
I got fed up with 10mm belts keep snaping on me,so I put a 12mm on and had no trouble's since.
Martyn Reed
D.O.C#491
EX Vin# 6064
