is there a parts cross ref for the aircon belt? - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 7 - Heating / Air Conditioning (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=20) +--- Thread: is there a parts cross ref for the aircon belt? (/showthread.php?tid=1633) |
is there a parts cross ref for the aircon belt? - steve.s - 09 Jun 2008 Hi i know it must be here somewhere, but its about time i tried to power up the aircon. does anyone know a reference?. thankyou - TheOriginalMrP - 09 Jun 2008 It's on here Steve if you've got a motoquip stockist close by.... http://www.deloreans.co.uk/forum/viewtopic.php?t=735 Or try this.... http://stits.org/DMCVEGAS%20DMC%20Archi ... X-Over.HTM Regards Re: is there a parts cross ref for the aircon belt? - Chris Hawes - 26 Jul 2012 The Correct sized Aircon belt is 10mm x 1350mm Gates 6234MC Re: is there a parts cross ref for the aircon belt? - Guinney1971 - 27 Jul 2012 that's good to know Chris, mine started smoking last year when one of my AC pulleys seized - luckily I was able to cut the belt off, and at some point in this millennia I will get around to changing the pulleys and the belt
Re: is there a parts cross ref for the aircon belt? - stunned_monkey - 27 Jul 2012 Chris Hawes Wrote:The Correct sized Aircon belt is 10mm x 1350mm No it isn't because the correct belt is 12mm or 1/2" wide. 10mm belts work for a short while but they "bottom out" on the pulley and start squeaking. Re: is there a parts cross ref for the aircon belt? - Guinney1971 - 28 Jul 2012 right........ glad I havent rushed out to buy one then! lol Re: is there a parts cross ref for the aircon belt? - Martyn - 29 Jul 2012 I got fed up with 10mm belts keep snaping on me,so I put a 12mm on and had no trouble's since. |
