Crank Shafts,
I think I probably know the answer to this one, however I shall ask the more enlightened (clever) out there :lol:
Is the crank in an auto engine the same as that attached to a manual gearbox? other than a different flywheel. If so is there a spigot bearing in the crank?
Thanks.
Hi Chris,
Yep the crank shaft is the same. It's the flywheel that's different. There should be a space for the spigot bearing to fit, but there wont be one in there.
Daniel Shane Wrote:Hi Chris,
Cheers Dan, Dont suppose you have the part number have you? I'm having trouble finding it in the manuals.
The pilot bearing is a standard size ball bearing
SKF 62032
40mm external, 17mm internal, 12mm thick
