Window control
Is the directional window control joystick supposed to work
Up - down - left - right ? Mine only works left right.
Mike
Mike Dargan
VIN #2311
DOC 697
...if you mean the side mirror adjustment joystick, then yes. Mine works in all 4 directions.
Ok then i have a problem. Mine only works horizontally ( side to side )
Is it likely to be the control stick or the motor behind the mirror that's on the blink???
Mike
Mike Dargan
VIN #2311
DOC 697
Could just be a loose connection.. When I got my car the passenger side mirror only went from side-to-side. After a week or so, with the doors being opened and shut several times, it started working up-and-down as well.. Has been fine ever since....
<crosses fingers>
Smile
Simon
Simon Brewer,
DOC Member #517
VIN #4748
Often the back of the switch itself falls off! would be worth checking that out as well.
This happened to me in the early days of my ownership... I bought a new mirror switch and it started working again before it actually arrived.
I blamed water ingress in the door.... and even found out a rodent had lived in one door for a short time some owners ago!
Every car has a story to tell!
