Window control - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: General Discussions on the DOC / Car / Company / JZD (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=25) +--- Thread: Window control (/showthread.php?tid=2906) |
Window control - Mrdashbo - 19 Oct 2010 Is the directional window control joystick supposed to work Up - down - left - right ? Mine only works left right. Mike Re: Window control - Rissy - 19 Oct 2010 ...if you mean the side mirror adjustment joystick, then yes. Mine works in all 4 directions. Re: Window control - Mrdashbo - 20 Oct 2010 Ok then i have a problem. Mine only works horizontally ( side to side ) Is it likely to be the control stick or the motor behind the mirror that's on the blink??? Mike Re: Window control - frostrobo - 20 Oct 2010 Could just be a loose connection.. When I got my car the passenger side mirror only went from side-to-side. After a week or so, with the doors being opened and shut several times, it started working up-and-down as well.. Has been fine ever since.... <crosses fingers> Simon Re: Window control - Chris Williams - 20 Oct 2010 Often the back of the switch itself falls off! would be worth checking that out as well. Chris Re: Window control - TheOriginalMrP - 04 Nov 2010 This happened to me in the early days of my ownership... I bought a new mirror switch and it started working again before it actually arrived. I blamed water ingress in the door.... and even found out a rodent had lived in one door for a short time some owners ago! Every car has a story to tell! |
