24 Sep 2008, 06:33
I need a new clip ring for my angle drive. The clip that holds it into the nut. Does anyone have any of these or know where they can be bought?
Wanted: Angle drive clip ring
24 Sep 2008, 06:33
24 Sep 2008, 09:38
Is it just a plain internal circlip? It's a while since I've seen mine (there- that's jinxed it!). In which case you might find them on ebay from nut/ bolt/ fastener suppliers etc if you're got the correct dimensions for it... Some car spares places have components boxes of these types of things too...
Derbyshire DOC 393 1981 DMC-12 VIN 06126
24 Sep 2008, 09:55
Its not a normal circlip unfortunatly as I have a box of them in my shed. Its kind of a wire ring type thing:
I bent mine up getting it out. Is it me or is that the most fiddly thing to get out ever! My angle drive seems to be working ok now though, it was a bit of a burr on one of the gears causing it to jam.
24 Sep 2008, 11:34
try contacting Speedograph Richfield (Nottingham), they make angle drives, speedo cables,
etc, and may be able to help you.
Jul 1981 DeLorean - Flopsy #2292 Aug 1989 Cavalier 1.6L - Guinney Apr 2021 Mokka-e Launch Edition - Evie #170
28 Sep 2008, 15:03
Cut a single loop off a spring of roughly the right diameter - it will work just fine
Richard H. DOC 365 VIN 1274
http://www.deloreans.co.uk In theory, theory and practice are the same. In practice, they are not. |
« Next Oldest | Next Newest »
