Wanted: Angle drive clip ring - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: DeLorean Cars or Parts For Sale or Wanted (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=26) +--- Thread: Wanted: Angle drive clip ring (/showthread.php?tid=1891) |
Wanted: Angle drive clip ring - Dan6457 - 24 Sep 2008 I need a new clip ring for my angle drive. The clip that holds it into the nut. Does anyone have any of these or know where they can be bought? Re: Wanted: Angle drive clip ring - Rich Hanlon - 24 Sep 2008 Is it just a plain internal circlip? It's a while since I've seen mine (there- that's jinxed it!). In which case you might find them on ebay from nut/ bolt/ fastener suppliers etc if you're got the correct dimensions for it... Some car spares places have components boxes of these types of things too... Re: Wanted: Angle drive clip ring - Dan6457 - 24 Sep 2008 Its not a normal circlip unfortunatly as I have a box of them in my shed. Its kind of a wire ring type thing: ![]() I bent mine up getting it out. Is it me or is that the most fiddly thing to get out ever! My angle drive seems to be working ok now though, it was a bit of a burr on one of the gears causing it to jam. Re: Wanted: Angle drive clip ring - Guinney1971 - 24 Sep 2008 try contacting Speedograph Richfield (Nottingham), they make angle drives, speedo cables, etc, and may be able to help you. Re: Wanted: Angle drive clip ring - Rich H - 28 Sep 2008 Cut a single loop off a spring of roughly the right diameter - it will work just fine |
