Anyone have one of these spare?
106734 AIR DEFLECTOR RH
http://delorean.com/dmcstore/ViewPage.asp?PageID=97
My car has been missing this part since I have had it. I am looking to find one, does anyone have one?
Also, DMCH sell the plastic edging strip for the hood 111388 + 111389
http://delorean.com/dmcstore/ViewPage.asp?PageID=93
If the pre-cut ones Houston have are as poorly cut as the strips already on my car (lengths are inconsistant and too short) then I am looking for a long roll that I can cut myself.
Chris Hawes Wrote:106734 AIR DEFLECTOR RH
Dave Howarth had/ has a pile of them, Im quite sure he still has some left, tho cant tell you if he has both sides or the side you are looking for Smile
Chris Spratt
1998 Lotus Esprit GT3
1999 Lotus Elise
DOC 4
Thanks Chris, I'll call Dave and see...
We've got a couple of each side with original dirt still on them Big Grin
Also got heatshrink adhesive bonnet edging - much better than the original crappy strips
Okay Mr smarty pants... what about this then...
The 3x studs for each of the afore mentioned panels are steel and rust:-
http://www.delorean.com/dmcstore/ViewPage.asp?PageID=97
SP10250 STUD M6X16 $8.97
Do you sell stainless ones that will grip to the fibreglass so that the stainless nut can be un/done?
The panel for the drivers side has the 3x studs situated in the lock-up box behind the seat. Are the ones for the passenger side panel sat under the battery?
Chris Hawes Wrote:The panel for the drivers side has the 3x studs situated in the lock-up box behind the seat. Are the ones for the passenger side panel sat under the battery?
Yes under the battery.
[Image: 3530.jpg]
http://www.pjgrady.com/specials.asp
got these on my car, god send ... cant imagine spending all that money on the #nasty# origional ones Smile
