Anyone have one of these spare? - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 8 - Frame / Body / Interior (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Anyone have one of these spare? (/showthread.php?tid=121) |
Anyone have one of these spare? - Chris Hawes - 07 Nov 2006 106734 AIR DEFLECTOR RH http://delorean.com/dmcstore/ViewPage.asp?PageID=97 My car has been missing this part since I have had it. I am looking to find one, does anyone have one? Also, DMCH sell the plastic edging strip for the hood 111388 + 111389 http://delorean.com/dmcstore/ViewPage.asp?PageID=93 If the pre-cut ones Houston have are as poorly cut as the strips already on my car (lengths are inconsistant and too short) then I am looking for a long roll that I can cut myself. Re: Anyone have one of these spare? - ChrisS - 07 Nov 2006 Chris Hawes Wrote:106734 AIR DEFLECTOR RH Dave Howarth had/ has a pile of them, Im quite sure he still has some left, tho cant tell you if he has both sides or the side you are looking for
- Chris Hawes - 07 Nov 2006 Thanks Chris, I'll call Dave and see... - stunned_monkey - 08 Nov 2006 We've got a couple of each side with original dirt still on them
- stunned_monkey - 08 Nov 2006 Also got heatshrink adhesive bonnet edging - much better than the original crappy strips - Chris Hawes - 08 Nov 2006 Okay Mr smarty pants... what about this then... The 3x studs for each of the afore mentioned panels are steel and rust:- http://www.delorean.com/dmcstore/ViewPage.asp?PageID=97 SP10250 STUD M6X16 $8.97 Do you sell stainless ones that will grip to the fibreglass so that the stainless nut can be un/done? The panel for the drivers side has the 3x studs situated in the lock-up box behind the seat. Are the ones for the passenger side panel sat under the battery? - bozzzydmc - 08 Nov 2006 Chris Hawes Wrote:The panel for the drivers side has the 3x studs situated in the lock-up box behind the seat. Are the ones for the passenger side panel sat under the battery? Yes under the battery. ![]() http://www.pjgrady.com/specials.asp got these on my car, god send ... cant imagine spending all that money on the #nasty# origional ones
