#2292 New engine
#46
Thanks Chris, have joined the forum and will take a look, we've been chatting to Josh on FB about adapter plates too.
Was this a suitable donor ?   it looked very good value for money it it was   http://www.ebay.co.uk/itm/P-1997-Peugeot...true&rt=nc  I can't help thinking we ought be be stashing one of these away before they all disappear.
I'd probably just buy the engine/gearbox - they go for £200 or thereabouts. I'm looking to farm out my engine rebuild at the moment (and gearbox) as I have some more pressing matters that require my time. However, I'll probably eat those words soon enough.
Member 101
VIN# 4566
Yes Dan, But I was thinking about all the computers and control gear that normally go with a modern-ish engine, in case you need them as well.
(06 Sep 2017, 08:35)Chris P Wrote: Yes Dan, But I was thinking about all the computers and control gear that normally go with a modern-ish engine, in case you need them as well.
Of course; with a manual it's really only the ECU and even then you may want to go aftermarket. It depends on what you want to achieve - I've seen a fair few with looms/ECUs. I've also seen plenty of bare engines - more common that not. Always a gamble.
Member 101
VIN# 4566
Great news Claire. That's the version of the engine FIL had in his 406 saloon. And that car was
a rocket ship!
Definitely worth looking at vented front discs and princess style calipers for the front brakes.
ATB
Nick H
DOC 650
Jaguar X-Type
DeLorean DMC 12 Vin#2862
My other hobby...
http://www.lccuk.org.uk/
ChrisP - the one we've got is the later D9 210hp version - the early cars had the 194hp version. The 210hp one was rejigged by Porsche apparently, and has things like separate coils or something, which makes them easier to sort and more reliable - its also pre-multiplex, so is pretty much 'plug n play' (so Phill tells me lol).
We want a complete donor car, so that we can also swap over to the modern air conditioning system, retro fit the cruise control, etc.
Obviously I've had to go for a Peugeot as I've got a manual box in my car, but those of you with automatics will have a bigger choice, as you can then raid cars like the Laguna 2, Citroen C5, Espace 3, etc etc. All of those, in UK spec, came with an automatic box. It would be lovely to find a way of using the standard 5spd auto with tiptronic from the Laguna/Avantime, but not sure how you'd do it, or even if its feasible.
aaaaand.................as you were.
Sale has fallen through Sad
Ah well, back on the hunt!!
Are you sure that engine block for Auto is different from Manual?
Usually it is the same as adaptor housing is doing the conversion. You need to replace flywheel and put clutch, but I would replace those components for new anyway.
I recall that one of my friends did swap from auto to manual on Z7X in Renault Safrane as they were all autos and he wanted manual. Transmission came from Laguna, I believe... Let me confirm that.
Interesting stuff Reinsch, once we've removed the engine, we can compare the differences. I'll change the clutch, the one in my car, although replaced in 2006, felt like it was needing changing again before my engine broke.
Anyway....... tomorrow, we're off to deepest darkest London to fetch a 406 Coupe, deal done, insurance arranged, just need to fetch it and cross the guys palms with some cash, and then I can drive it back - this one is MOT'd until next August, so sounds better then the other heap we were looking at in Cheshire (that had no MOT so would need a trailer). If it drives ok, I'll smoke around in it for a bit and make sure the engine is ok - there's no major hurry to scrap it, as we're not in a position yet to pull the engine out of Flopsy and do the frame separation.
Watch this space!
Great news Claire. I watch with interest because of all the things. Smile
Member 101
VIN# 4566
Ok, so the donor car is home Smile
Visually, its a shed, so I've no qualms about scrapping it.  The engine runs really nicely, and boy is it quick when you squirt the accelerator!  It does however have a problem with the steering rack, which was probably caused during the front and rear end damage it sustained in 2014.
Its done 112,000 miles, service records and bits of history with it up to 96000.  Last two owners were in the same family.
Photos attached! Smile
The Beast
https://flic.kr/p/Ys3FiU
Engine
https://flic.kr/p/Ys3GTY
Lovely full leather heated memory seats.......
https://flic.kr/p/Y76nbo
XFX Denotes the later version of the engine with VVT and more power at lower revs.
https://flic.kr/p/YuD99X
https://flic.kr/p/XtfD5e
More engine photos
https://flic.kr/p/XtfDAe
https://flic.kr/p/YuD9Cx
The battered bodywork....its clear the car has been hit front and back, the NSF alloy has a big chunk out of it and the NSF wing is full of filler and has been 'painted' with a rattle can (not visible in these photos, but I'll put some more up later for full comedy effect.
https://flic.kr/p/Ys3Eq1
https://flic.kr/p/Y76mGY
https://flic.kr/p/Y76mWA
Hopefully the photo links work ok, I've given up with Photobucket and am trying Flickr for the first time.
Yes all the links worked Claire. The seats look nice and comfy...cant wait to see how you get on with it! Smile
The seats are very comfy, just wondering if they'll fit the De Wink
Claire, in Flickr you can export the links as BBCode and it'll do it in various sizes. Then you can display them here on the forum without needing to click-through. It's how I use Flickr for all of my pics.
Very nice; shame it's in such poor cosmetic condition, but then, that'd be a good car and breaking good ones is never ideal. Looks like a win.
Member 101
VIN# 4566
