Threads: 21
Just spoke to Phil at SOC - apparently if I get them the UJs and the shaft they send it off to get refurbed. Takes just over a week and costs £60. Could be a good solution if it's not the SD1 bit that's knacked... Thanks Al!
VIN 7176
DOC 643
No probs, maybe a refurbed steering rack is something the club could look at on the spares front etc.
Threads: 21
Here's the latest on this saga - the SD1 part isn't the right one, so Chris is sending that back to Rimmer Bros. I've also decided to go down the new part route rather than the refurb route, so it's €143 to Ed for a new lower UJ. Also getting his poly ARB-LCA bushings at the same time (€43). Hopefully the car will drive like it should by Eurotec!
VIN 7176
DOC 643
Threads: 21
bozzzydmc Wrote:http://www.delorean-parts.com/Merchant2/...y_Code=521
Heard some nice reports on this ....
Yes, Ed's got a custom all in one unit too for €280. I considered it but I'm not sure it'll make all that much difference if the rest of your shaft assembly is OK. If you're not careful you can really plunder thousands on these idiotic cars
VIN 7176
DOC 643
Yes very true ! ... so your other UJ is ok then buddy?
Threads: 21
bozzzydmc Wrote:Yes very true ! ... so your other UJ is ok then buddy?
I haven't seen it myself, but I'm taking Chris's advice (as with most other things on the car too!). He thinks the upper is good enough not to warrant changing the whole lot so I'm happy to go with that
VIN 7176
DOC 643
Threads: 79
Just so you know, Ed's poly bushes are the same as the superflex ones you can buy over here.
Threads: 56
Dan1986 Wrote:Just so you know, Ed's poly bushes are the same as the superflex ones you can buy over here.
Hi Dan,
A little off topic i know, but I want to tighten up the front end on my car with new poly bushes, when you did you car did you buy a 1-off kit that had all the required parts? and if so where did you get it from?
James
Threads: 79
Hi James, I bought this kit which comes with everything for the antiroll bar:
http://delorean-parts.com/Merchant2/mer ... de=K1006DP
Threads: 21
Dan1986 Wrote:Hi James, I bought this kit which comes with everything for the antiroll bar: http://delorean-parts.com/Merchant2/mer ... de=K1006DP
They'll also sell you the four bushings for the ARB - LCA separately for $45 plus shipping. Misty there is very helpful.
VIN 7176
DOC 643
Threads: 56
Cool I've ordered that kit, now where's the best place to get new trailing arm bushes? i've seen them for around £100 a set, does that sound like the best price?
I need to do these bushes urgently as my car is scary to drive
J
Threads: 79
The superflex trailing arm bushes are 50 quid each direct from superflex so I don't think you will beat that. New rubber ones are a LOT cheaper though.
Threads: 56
Dan1986 Wrote:The superflex trailing arm bushes are 50 quid each direct from superflex so I don't think you will beat that. New rubber ones are a LOT cheaper though.
Are the new rubber ones ok, or should I just stump up the cash for the poly bushes?
J
Threads: 79
I used new rubber ones as I didn't think having those is poly would be that important. I just used polly for the main links etc as they take all the loading when cornering.
