LAMBDA COUNTER
Hi all i was just thinking about my lambda counter because i am coming up to around 29k do i need to reset it or ignore it as i may be getting rid of sensor Cheers TONY TT
Apart forom the light coming on the dashboard telling you something you already know Smile Smile
Found this, personally i would just reset it :-
( From Michael A. Griese )
The Lambda counter is located under the dashboard
next to the steering column. The speedometer cable
passes through the counter (that's why there are
upper and lower speedometer cables). The counter
measures percent of use of the oxygen sensor, and the
sensor has a predicted 30,000 mile life. That means
that a Lambda counter showing 020 has travelled about
6000 miles since the last reset (20% of 30,000). The
counter should never vary more than about 250 miles
from the odometer. If it does, your odometer has been
tampered with or your car has had a rare upper
speedometer cable failure.
To reset the counter, remove it from the car and look on
the right side. You should see a small plastic disk with
two holes in it. Using a pair of snap ring pliers (needlenose
work also) rotate the disk until the counter reads 000.
You should also replace your oxygen sensor at this time.
http://mydelorean.net/html/howto/howto2 ... -Emissions
Thanks Mike that'l do me Tony TT
TRY:-
and navigate from there Smile
Universal single wire Zirconia (0-1v) 18mm spark plug thread.
You could also give Dave Howarth a call as he has boxes full of new old stock OEM Bosch.
If the base fuelling is not correct then the lambda reading will be saturated at one end or the other and will not give the desired switching.
Yes dave Howarth has them about £30 i think TT
