LAMBDA COUNTER - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 2 - Emission / Fuel Systems (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: LAMBDA COUNTER (/showthread.php?tid=506) |
LAMBDA COUNTER - Tourettes Tony - 12 Apr 2007 Hi all i was just thinking about my lambda counter because i am coming up to around 29k do i need to reset it or ignore it as i may be getting rid of sensor Cheers TONY TT - bozzzydmc - 13 Apr 2007 Apart forom the light coming on the dashboard telling you something you already know ![]() ![]() Found this, personally i would just reset it :- ( From Michael A. Griese ) The Lambda counter is located under the dashboard next to the steering column. The speedometer cable passes through the counter (that's why there are upper and lower speedometer cables). The counter measures percent of use of the oxygen sensor, and the sensor has a predicted 30,000 mile life. That means that a Lambda counter showing 020 has travelled about 6000 miles since the last reset (20% of 30,000). The counter should never vary more than about 250 miles from the odometer. If it does, your odometer has been tampered with or your car has had a rare upper speedometer cable failure. To reset the counter, remove it from the car and look on the right side. You should see a small plastic disk with two holes in it. Using a pair of snap ring pliers (needlenose work also) rotate the disk until the counter reads 000. You should also replace your oxygen sensor at this time. http://mydelorean.net/html/howto/howto2 ... -Emissions - Tourettes Tony - 13 Apr 2007 Thanks Mike that'l do me Tony TT - bozzzydmc - 16 Apr 2007 TRY:- http://mydelorean.net/ and navigate from there ![]() - NickT - 16 Apr 2007 Universal single wire Zirconia (0-1v) 18mm spark plug thread. You could also give Dave Howarth a call as he has boxes full of new old stock OEM Bosch. If the base fuelling is not correct then the lambda reading will be saturated at one end or the other and will not give the desired switching. NickT. - Tourettes Tony - 16 Apr 2007 Yes dave Howarth has them about £30 i think TT |
