Threads: 16
Am I missing something here? Like a rubber stopper or something that covers the idle mixture hole? How does this compare to other people's?
Would appreciate the advice here.
Stephen Partt
Bristol
Threads: 28
That hole should be blocked, otherwise unmetered air will enter the manifold, which will screw up your mixture. Not by a lot, but it does make a notable difference.
I have seen many things used including chopped down golf tees, the end of a silicone cartridge (that used to be mine) and a suitably sized bolt.
There is a pretty rubber stopper with a hoop on the end available from Houston
PLUG, REMOVEABLE 102392A:
http://store.delorean.com/p-6399-plug-removeable.aspx
Threads: 16
Thanks, I did think that was the case, just wanted a second opinion to be sure.
Stephen Partt
Bristol
Threads: 26
Steve,
I have one of these plugs on the shelf. If you need one drop me a PM.
Threads: 16
Hi Mike
Aahh no, already bought one from Ed. Thanks for the offer though.
Stephen Partt
Bristol
Threads: 26
No worries Steve
