06 Sep 2022, 15:18
(06 Sep 2022, 11:53)Guinney1971 Wrote: An update:
as we had a friend who wants to use some of our garage space to store some Porsche parts,
we were given the kick up the bum we needed to roll the chassis out clean it up, and see how
bad it is.
The gearbox was a pig to get out, and the fuel tank came out with a few sheared bolts, and the
tank panel is pretty rough, but we think saveable.
However, after a thorough degrease and pressurewash, we've got a good idea what the car needs,
and although its not pretty, it is mostly surface rust, the only unknown, being the box section under
where the engine goes. That will need further investigation. Phill has also made a start on the
modifications to the Rover V8 sump so that it will clear that section of chassis when the new engine
goes in - that needs a new camshaft (tempted to go for a performance cam, even though its around
£250 instead of about £80 for a standard one) - we've already picked up a complete Rover V8 testbed
to run the engine up on when its built up. The engine will have an electric water pump, and we are
also looking at electric air con system and power steering.
I'll do an update for DeLorean News with photos so you can see Frame #01944 in all its 'glory'.....
Claire if you plan on getting the frame blasted and recoated, vibrant coatings near me have a booth and tank more than large enough for the frame + extra.
i found out through Rebel classics who are under the same owner as vibrant as they did a DeLorean frame not long back.
Vin: 5222, 81 grey auto "Ryuko"
