Universal Steering Joint - cross matchable? - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 5 - Suspension / Steering (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Universal Steering Joint - cross matchable? (/showthread.php?tid=2167) |
Re: Universal Steering Joint - cross matchable? - NickT - 10 May 2009 I personally haven't put superflex solid bushes on the trailing arm bolts as the rear suspension in normal movement induces an arc at the TA Bolt so needs some flex. I put new rubber ones on as this area requires some compliance. I would be interested to see long term the TA Bolts in hard silicone bushes in this area to see if they have bent. All other ones would be fine with silicone ones (although do expect a harsher ride!) NickT Re: Universal Steering Joint - cross matchable? - JamesRGUK - 10 May 2009 Dan1986 Wrote:I used new rubber ones as I didn't think having those is poly would be that important. I just used polly for the main links etc as they take all the loading when cornering. Where did you get the rubber ones from? DPNW too? Re: Universal Steering Joint - cross matchable? - jerzybondov - 10 May 2009 JamesRGUK Wrote:Dan1986 Wrote:I need to do these bushes urgently as my car is scary to drive So was mine at Easter! I'm hoping that new rear shocks, ARB poly bushes, steering column bushing and new UJ will sort it out but there's a chance the TABs will need looking at too... Do you have play on your back wheels when they're in the air? And what are the symptoms when you're driving? Re: Universal Steering Joint - cross matchable? - JamesRGUK - 10 May 2009 NickT Wrote:I personally haven't put superflex solid bushes on the trailing arm bolts as the rear suspension in normal movement induces an arc at the TA Bolt so needs some flex. I put new rubber ones on as this area requires some compliance. I would be interested to see long term the TA Bolts in hard silicone bushes in this area to see if they have bent. I notice I can buy rubber TAB bushes from Delorean.com but they are NOS are they available 'new' or should I be ok with NOS? J Re: Universal Steering Joint - cross matchable? - JamesRGUK - 10 May 2009 jerzybondov Wrote:So was mine at Easter! I'm hoping that new rear shocks, ARB poly bushes, steering column bushing and new UJ will sort it out but there's a chance the TABs will need looking at too... Classic worn TAB bushing symptoms are similar to wheel tuck that you get on old triumphs, it just feels like the back end is floating around and twisty when cornering. Front end is feels quite 'distant' under heavy braking, thats the only way can thing to describe them. No they don't have obvious play when off the ground, but it is hard to manually replicate the kinds of forces put on these joints when the car is in use. J Re: Universal Steering Joint - cross matchable? - Daniel Shane - 10 May 2009 The TAB's are exactly the same as Lotus used on the Esprit as the Rear Radius Arm Bushing. You can get them brand new from Lotus. The Last one I got from them cost about £15. Dan Re: Universal Steering Joint - cross matchable? - JamesRGUK - 10 May 2009 Daniel Shane Wrote:The TAB's are exactly the same as Lotus used on the Esprit as the Rear Radius Arm Bushing. Thanks Dan, This may sound daft, but where do I actually go to buy Lotus stuff? James Re: Universal Steering Joint - cross matchable? - Daniel Shane - 10 May 2009 There should be a Lotus dealer near to you, If not are you going to Eurotech this year ? If so you can drop into the factory on the way home and purchase parts Dan Re: Universal Steering Joint - cross matchable? - ChrisS - 10 May 2009 JamesRGUK Wrote:This may sound daft, but where do I actually go to buy Lotus stuff? http://www.sjsportscars.co.uk/ |
