22 Oct 2007, 11:36
Bad luck..... No one will ever guess!
Rear Fog Light
22 Oct 2007, 11:36
22 Oct 2007, 11:50
Chris Hawes Wrote:wiring up the foglamps like this used to be in the members area of the club website I think... Restored from backup. http://www.deloreans.co.uk/members/tech ... ights.html I would personally wire it using diodes and solder/crimps, although the write up may have been updated since my latest backup. I wired mine using this: http://www.dmcnews.com/Techsection/eurolites.html NickT.
23 Oct 2007, 18:27
any particular flavour of diode we should be looking at? :lol:
I've looked here: http://rswww.com/cgi-bin/bv/rswww/searc ... &Nr=avl:uk
- Dave Smith VIN: #00944 DOC: #535 VIN: #03193
24 Oct 2007, 09:05
I just used mains 13Amp 230v ones as I had some of these of my shelf.
Nick.
24 Oct 2007, 19:01
NickT Wrote:I just used mains 13Amp 230v ones as I had some of these of my shelf. Are you sure these weren't the 3 phase 415v type?
24 Oct 2007, 19:23
hahahahahhahahaha!!!!!!!!!!!!!!! :lol: :lol: :lol: :lol: :lol:
love the new avatar Nick!!!! Hey, with Hallowe'en coming up, you could do an extra special scotchlock, after all, they might as well have come out of satan's ar$e! :lol:
Jul 1981 DeLorean - Flopsy #2292 Aug 1989 Cavalier 1.6L - Guinney Apr 2021 Mokka-e Launch Edition - Evie #170
25 Oct 2007, 11:59
08 Apr 2008, 19:41
old thread, but never mind -
I'm going to use the lambda light for a fog tell tale. Does the light have to say 'fog' on it or have the rear fog symbol on it? or does it just have to light up when the fog light switch is depressed?
08 Apr 2008, 19:45
Barson Wrote:old thread, but never mind - You will be ok with that light coming on when the switch is depressed ... thats all the MOT standard says .
08 Apr 2008, 22:20
Yep mines like that too, its just spliced in so the lambda light is still connected to the counter but also comes on with the fog lamp.
09 Apr 2008, 09:59
The wiring should really have a diode to prevent the voltage from the lamp back feeding into the fuel computer (, unless of course the computer is not used anymore and has been disconnected)
09 Apr 2008, 16:50
presumably that's only if i retain the lambda light facility and only splice in the fog switch, rather than disconnecting the lamp from the counter and connect it up to the fog switch.
09 Apr 2008, 17:44
Thats right.
NickT |
« Next Oldest | Next Newest »
