Fancy a turbo project? :-)
l would'nt mind this myself;
http://cgi.ebay.com/ebaymotors/DELOREAN ... enameZWDVW
Postage might be a tad expensive though
not a bad price especially for 2 turbo's the only problem i can forsee is the oil seals could have perished so 2 rebuilds, im not so sure TT
it's been $2000 for afew days now. I'm waiting till 5 minutes to go then checking on the price. Smile
- Dave Smith
VIN: #00944 DOC: #535
VIN: #03193
well if you fancy it mine works fine now but you wont be able to run any more boost than a single, cos your injectors will pop out and any vacuum pipes will come off, plus you have to sort out the ignition timing, plus loads of other bits, its work but worth it :wink: tt ps sub 20mpg Cry
Tourettes Tony Wrote:well if you fancy it mine works fine now but you wont be able to run any more boost than a single, cos your injectors will pop out and any vacuum pipes will come off, plus you have to sort out the ignition timing, plus loads of other bits, its work but worth it :wink: tt ps sub 20mpg Cry
I'm running sub 20 mpg without turbo's at the moment. Must get a c/o meter!
i think that may be some thing to do with your right foot chris :wink: TT
Sold for $3050 so about 15-1600£
Not bad I suppose really for two turbo's and all the gubbins that goes with it. Especially when a performance exhaust cost nearly that much! Mind you I cant afford either anyway Sad
well i spose you could call me lucky with mine, i didnt even notice the kit was on mine until crispy noticed it on the pics, just goes toshow how blind i was Cry TT
