your craig.....have you any transformers?
Hi
my Craig is dead....got my head under the dash, wires out the back to black plastic wrapped bundle.
cut plastic off and found transformers underneath. (assume ofr impedance for speakers?)
i cannot see any fuses.
pink wire not connected.
any ideas.
Follow past the transformers to the white multiplug then keep going past the multiplug and you will find two in-line fuse holders.
Check both fuses - one is for switched 12v and the other is constant 12v for the station backup. Highly likely one or other has blown
thanx
i'll take a look...have not seen anywhere about transformers near the Craig.
Thats what foxed me.
steve.s Wrote:pink wire not connected.
That pink wire should go to the radio antenna Steve if my memory is correct. I'm guessing your car would have had the antenna in the windscreen originally?
hi
thanx Phil.
i've go a feeling pink should not be connected.
is the feed for radio on power for..elec aerial.
i will have another look for these darn fuses.
i have tried to remove the nuts holding the wiper system on.
one nut is done, the other spins on the shaft!. bugger!!
i was trying to get under the dash to see if i can mole grip the other end.
the thing still seems to work though (so far).
just not enough time in the day.
Users browsing this thread:
