24 Jul 2007, 23:04
Hi guys,
Has anyone else experienced problems with coolant hoses underneath the car not sealing properly? I've got two hoses which are leaking on VIN# 4400 at the moment and it's really beginning to get on my nerves. They are the ones which run either side of the gearbox (sort of) and connect to the pipes which go up around the engine. Or for those of you who know the underside of a DMC-12 intimately: it's the two hoses which are at a funny angle near the back of the car when you look underneath :wink:
I replaced these 2 pieces of hose about 6 months ago with brand new correct hoses from 'a well known DMC vendor' and I also bought some stainless jubillee clips to finish the job. When I first fitted the hoses I took the car on a test drive, checked the system for leaks and found everything was fine. But whenever I leave the car for a few weeks or longer without driving it, these two hoses leak a small amount of coolant onto the garage floor. It seems to happen regardless of what the outside temperature is so I don't think the hoses are contracting with cold weather or anything like that.
At first I simply tightened the clips a little more but this didn't seem to make any difference and I'm worried that over tightening them is going to damage the actual water pipes themselves.
Tonight I tinkered about with the hoses a bit, jiggled them around to try and make them a better fit and then re-tightened the clips closer to the edge of the hoses to see if it makes any difference.
Anyone got any ideas about what to try if this doesn't work?
(By the way, the only reason I'm overly grumpy about the situation is that tonight was one of those very rare weekday nights when I actually get to go home to Wolverhampton. I'd wanted to take VIN# 4400 for a spin down my favourite stretch of road out towards Shropshire but alas I thought I should deal with this cr@ppy coolant hose problem before driving her anywhere.
Phil Peters
VIN# 4400 (in the dog house, big time)
Phil Peters
