25 May 2007, 21:19
I know it's sad to watch BTTFs over and over again millions of times weekly, but I used to do that when I was still at secondary school when I had no internet or cars to "play" with.... :roll:
By doing so, I have spotted so many flaws and shots that shows different object placements/ settings... which they aren't meant to be.
BTTF 2 is the one which I have spotted most flaws. When DOC and marty first landed at the future Hill Valley, the shots switch between the real and the fake D (for flying shots).... First, the fake D has poking out wheel nuts, silver centre badge, the doors don't shut, and I remember there are differences between the white tyre lettering too!
Then when they opened the door, passenger side's door mirror is bent to the closed position, but then the next second, it's back in normal position. Also, some shots shows the D have door straps, but some shows no door straps fitted...
Then for the shot when Doc has to chase behind Biff's car in 1955, the shot clearly shows the fake D's rollers. And the welded wheel too! But not sure if I am correct, you could also spot one of Marty's body harness' buckles that kept him "hoovering".
And in all three of the films, there are 2 different versions of the digital speedometer, one with 2 digits but third digit blanked out with black tape, one with 2 digits but first digit blanked out.
Anyway, I know this is a rubbish post, but just wanted to share the above pics which I have found in my hard drive when I was backing up the data. If I find more, I would probably add to the list if you guys don't mind? I am not putting down the films... they are clearly legend and I love all three of them! I am doing this just for a good laugh :wink:
Kind Regards,
John [DOC No. 8]
John [DOC No. 8]
