First show!
Hi all,
After a long resurrection and a few "test drives" (in reality, confidence building drives), I took 4566 to Goodwood on Sunday for their Goodwood 75 Breakfast club. The drive, especially home, highlighted a couple of issues; in particular that she doesn't like staying in 5th gear for some reason... otherwise, a lot of heavy traffic meant the cooling system got a work out, so that's at least something positive.
https://www.goodwood.com/grr/event-cover...fast-club/ - she's on the site!
[Image: 52954142072_fef3b72355.jpg]Goodwood 75th by Dan Willis, on Flickr
[Image: 52954878634_57bc4f04fc.jpg]Goodwood 75th by Dan Willis, on Flickr
[Image: 52954878729_3cfc3b3b20.jpg]Goodwood 75th by Dan Willis, on Flickr
[Image: 52954142212_f490f489ea.jpg]Goodwood 75th by Dan Willis, on Flickr
[Image: 52954142242_d34ca0fd3c.jpg]Goodwood 75th by Dan Willis, on Flickr
[Image: 52954142287_302180f905.jpg]Goodwood 75th by Dan Willis, on Flickr
On returning home I started taking her apart! Haha... not really, but I had to sort some bits out; I had no aerial reception (fixed), my driver's side door lights failed (the connector fell off) and I couldn't get the engine cover open (maybe heat?; it's working now...). Also, my gear gaiter tore along one side and it appears to be glued to the center console rather than via metal clips. Little mysteries.
All part of the classic-car ownership fun. It was a very positive morning, especially representing a year on the Goodwood grid!
Member 101
VIN# 4566
Awesome! Thanks for sharing. Never been to Goodwood. At least i don't think i have, but that tunnel in your picture does seem memorable somehow.
(5th gear issue). Is the detent ball bearing in place on the transmission? (Not sure if you've had the transmission apart or not)
(06 Jun 2023, 12:36)Rissy Wrote: Awesome!  Thanks for sharing.  Never been to Goodwood.  At least i don't think i have, but that tunnel in your picture does seem memorable somehow.
That's great - I've never been to Goodwood either but I know it comes highly recommended.  Do you reckon it could be a goer for a club excursion at some point Dan?  (I'd need something likel that as an impetus to actually go, as it's a fair trek from here!)
Looking mint there, you must be really proud of it.
Awesome Renault 5 Turbo beside you there, and it that a Peerless you're behind?
Great stuff Dan, I'm sure you'll sort the niggles out in time.
The transmission has been out and opened and the detent ball was actually replaced; I'll be doing some investigation; it could be adjustment (though less likely, it's worth a nip on the nut) or the big "nut" may be loose. I don't fancy draining the gearbox oil but needs must.
There's always a club event on at Goodwood; I think for us the question will be that it's as far south as one can go before drowning, so for much of the club it'd be a long ol' jaunt. I'm happy to look in to it and report back if the general mass thinks it worth the question.
I'm sat, there, between the R5 (engine in the back!) and a 205 GTi. The row kinda went through the ages as it was the Goodwood 75th; I was obviously very much in the 80s. I was in good company!
Member 101
VIN# 4566
good for you Dan.
Users browsing this thread:
