25 Jan 2023, 08:26
I tried social media for an answer, and nobody could give me one. I’m hoping someone here knows.
I’m thinking about changing out my battery cables. That is, the chunky cables which go between the battery terminals and elsewhere. The purpose behind this is to give me the easier option of a posted battery rather than the original terminal style. Side terminal batteries are thin on the ground and getting fewer options every time I need to consider a new battery.
I’m interested in keeping my original cables intact, so therefore would like to fully replace what’s there with new, hopefully more flexible made up cables.
So, with everything explained and hopefully justified, I’m after someone telling me the dimensions of the cables I need. Cross sectional area (mm2) or at least diameter or even better gauge or amp capability. And of course, length so I have enough in each length to get from the battery to the other end with room to spare for pulling the battery in and out of its cubby hole.
I’m hoping someone can come through for me here. Social media just seems to sport on additional questions etc from others rather than a simple straight answer to a simple straight question. I don’t mind the other comments etc from others if they answer the question first. But to only bring those to the table with no actual answer to the original question. Well I find this frustrating.
Thanks in advance. I hope.
