Door issue
Hi all,
I’ve noticed that when my driver door opens fully, it’s rubbing against the corner of the t panel. I think this might be pretty common but I just wondered if anyone has come up with a way to fix it, or do people just ignore it?
Thanks
Darren
Darren Hirons
Leeds
DOC 1014
VIN 10579
Normally, what I do if I've had the T-panel off; when putting back on, I open up both doors and set the T panel in the middle according to the door positions at the open position. This is normally good enough to stop this rubbing you're speaking off. So you could try loosening off the T panel at the screws and do what I do.
(07 Mar 2022, 09:50)Rissy Wrote: Normally, what I do if I've had the T-panel off; when putting back on, I open up both doors and set the T panel in the middle according to the door positions at the open position.  This is normally good enough to stop this rubbing you're speaking off.  So you could try loosening off the T panel at the screws and do what I do.
Thanks mate. i'll give it a try.
Darren Hirons
Leeds
DOC 1014
VIN 10579
