08 Nov 2021, 10:55
Hi All!
Recently noted a bit of an oddity with my car on starting.
Having had old cars before, I have a habit of turning key from off to first position then second position slowly, then waiting in second position to hear fuel pump going - leaving for a bit to make sure system pressurised and fuel is in all lines, before finally turning to 'start'. Hopefully avoiding unnecessary fuel-less cranking..
Currently, however, in my D;
Turn key through first position to second position, and there's an odd buzzing noise from somewhere behind me on the LHS.
And the fuel pump appears not to be going.
Turn key back to 'off', then turn back through first to second position. No problem, pump is going as normal. Continue turning key to 'start', no worries, off she goes.
However, even after a bit of running, if I then turn her off (at a petrol station, say) - the whole malarkey happens again!
So, I call it a binary pump issue, as every time I get in to start her up, there's a first turn of the key to position 2 with no fuel pump (0) and an odd buzzing noise, then on the second turn of the key to position 2, fuel pump winds up perfectly normally (1) 'cos I can hear it, without the buzzing noise.
Any thoughts?
Yours confusedly,
Ivan
Any thoughts?
Yours confusedly,
Ivan
