Rear cv gaiters
i have just noticed one of my outboard rear gaiters has split, i heard some where they are ford granada if not has anyone got the part #
love TT
Yes they are 1981 (ish) Ford Granada
Quinton Hazell Part Number: QJB122
Moprod: CVK193
Copy from Dan Shanes list
"Motoquip Part numbers. Most Motorfactors will either have them as Motoquip parts or can reference them over to who ever they use.
CV Boot VCV221"
thanks rich thanks bozz im on it TT Smile
Hi all
Can I ask for a definate confirmation that these are good for the CV boots??
VCV221
Anyone here bought and fitted these. Right size? As good/same as Ed's stock??
http://www.ebay.co.uk/itm/Quinton-Hazel ... 4658wt_919
Thanks a lot,
a
I think BTTF car recently had these fitted to his: http://www.psautoparts-store.co.uk/inde ... uct_id=163
and I think these are the ones MatrinG used to fit, but I will let him confirm if it is.
Mmmmhmmmm....
Thanks Chris.
Any other info appreciated, but these are then getting closer in price to Ed's 14.28 GBP equivalent, which I know will fit, and I need some other parts anyway...
As opposed to 4 off the wrong part, which is expensive!
a
I can guarantee QJB122 will fit. I've used them myself, that's how I know the part number :wink:
They come in at around 8 quid each on eBay
To be honest though, from experience these new 'rubber' gaiters only last a couple of years before they need replacing again.
Whatever material they use is nowhere near as good as the OEM stuff. I had a spare one on the shelf and even without use it had started to perish! Shock
I got sick of doing the job so invested some time in finding an alternative.
Look for Neoprene Extra Stretchy Universal Fit CV Boots the material is far superior, much more flexible and less prone to splitting.
They are designed to be fitted using a special fitting cone without the need to remove the CV joint, but you don't have to buy a fitting tool and can still use them like a standard boot. You have to cut them to size, but it's easy to do.
I've had a set on my D for a good few years now and they are holding up much better then the other type.
Also interesting, thanks...
Will look for neoprene ones then.
Thanks for the heads up. Not a job I want to do twice!
a
Neoprene type..highly recommend Ballcast....
your motor factors will have em on the shelf. Get the cone or borrow one...lube it up and simply slide the new boot over the joint for a perfect fit. clip it up job done.
Idea don't forget to turn it inside out first ...You'll see what I mean.Mr Green
