40 DMC Parts (17 new / 23 used) some are rare items, auctions end Sun 14th Feb 21
I’m having a clear out of new/used parts.  Some of these parts (new and unused) are no longer available from any of the vendors.  All of the items finish in the evening of Sunday 14th February GMT.  Shipping is free to all UK buyers.  International buyers are welcome, but please contact me before bidding so that you’ll know what your shipping rate will be.
New
111388            Hood Edge Strip 44" –Side
https://www.ebay.co.uk/itm/164686042882
111389            Hood Edge Strip 59" – Top
https://www.ebay.co.uk/itm/164686043971
105542            Brake Servo OEM New
https://www.ebay.co.uk/itm/164686045068
100289            Stainless Brake Servo Booster Mounting Bracket
https://www.ebay.co.uk/itm/164686045644
108534            The DeLorean Go Silicone Rubber Door RH Fixed Glass Perimeter Seal
https://www.ebay.co.uk/itm/164686046998
108533            The DeLorean Go Silicone Rubber Door LH Fixed Glass Perimeter Seal
https://www.ebay.co.uk/itm/164686047779
108205            accelerator pedal cover only
https://www.ebay.co.uk/itm/164686054239
106130            angle drive
https://www.ebay.co.uk/itm/164686054719
108737            hood seal
https://www.ebay.co.uk/itm/164686055873
SP10497         INNER DOOR SEAL EDGE CLIP
https://www.ebay.co.uk/itm/164686057896
106781            No Drip Tape
https://www.ebay.co.uk/itm/164686058941
100701            LH OEM NEW belt and OEM NEW receptacle inc OEM NEW plastic cover
https://www.ebay.co.uk/itm/164686060176
100702            RH OEM NEW belt and OEM NEW receptacle inc OEM NEW plastic cover
https://www.ebay.co.uk/itm/164686064308
105085            OEM EXTERIOR MIRROR ADJUSTMENT SWITCH
https://www.ebay.co.uk/itm/164686067587
108209G         PJ Grady Gas Strut - Louvre (single)
https://www.ebay.co.uk/itm/164686068393
105257            Rubber boot for lower ball joint/tie rod end/track rod
https://www.ebay.co.uk/itm/164686069011
Used -    All of the below are original OEM 1981 parts from an Oct 1981 build
100181            11 used OEM wheel nuts
https://www.ebay.co.uk/itm/164685865497
100701            LH OEM belt used and NEW OEM receptacle not inc plastic cover
https://www.ebay.co.uk/itm/164685872895
100702            RH OEM belt used and NEW OEM receptacle not inc plastic cover
https://www.ebay.co.uk/itm/164685874595
110416            Mirror glass
https://www.ebay.co.uk/itm/164685879588
110520            Fuse Box Cover
https://www.ebay.co.uk/itm/164685885582
101064O         Original (Black) RPM relay
https://www.ebay.co.uk/itm/164685888561
106720            RH REAR SPEAKER BRACKET
https://www.ebay.co.uk/itm/164685900516
106721            LH REAR SPEAKER BRACKET
https://www.ebay.co.uk/itm/164685896916
108748            OEM grooved ash tray
https://www.ebay.co.uk/itm/164685920726
108288            OEM Cigar Lighter complete with illuminated ring
https://www.ebay.co.uk/itm/164685924396
110523            Console Cover grey
https://www.ebay.co.uk/itm/164685928433
110521            Console Tray grey
https://www.ebay.co.uk/itm/164685930951
105104            Speedometer Drive Dust Shield
https://www.ebay.co.uk/itm/164685966449
101440            STORAGE (CUBBY BOX) LOCK
https://www.ebay.co.uk/itm/164685942707
105610            Dummy Switch pair
https://www.ebay.co.uk/itm/164685944319
https://www.ebay.co.uk/itm/164685944911
101488            Tail Light Boards with Incandescent Bulb Kit
https://www.ebay.co.uk/itm/164685970285
100169O         OEM drive shaft
https://www.ebay.co.uk/itm/164685971406
118702            Rear wheel (hub area needs repair)
https://www.ebay.co.uk/itm/164685986378
101044            OEM Starter Motor
https://www.ebay.co.uk/itm/164686006120
100462            Clutch Master Cylinder DMC
https://www.ebay.co.uk/itm/164686009559
110085            OEM Fuel Pump Bosch
https://www.ebay.co.uk/itm/164686011679
108683            Fuel Tank Baffle Outer Retainer Spring
https://www.ebay.co.uk/itm/164686016830
100817            Lamp Delay Unit
https://www.ebay.co.uk/itm/164685948670
If you have any queries, please message me via the listing on eBay.
Best wishes
