Rear hub wanted
Exclamation
Hello,
I'm in need for rear hub as mine has damaged splines.
I only need part of hub with studs, important part are splines - they need to be in very good condition.
Photo for reference :
[Image: 5r3o9LQdCi3bvUp4pMQ--bK9USoWK1aJm7tYgUmJ...98-h973-no]
If you look carefully, left one has damaged splines, right one is perfect. I'm looking for one like the one on the right. They can be corroded, not a problem.
Marek "Reinsch" Kaminski
Reinsch Engineering Limited
Owner of #4454 - Restomod build in progress
Facebook group "Delorean vin 4454"
Might be worth a message to Steve (Scatman) I know we did a hub/carrier swap on his car. I also know he has some bits but I cant remember what!
Hi Chris, thanks for tip!
Can you confirm his exact nick? I can't find anybody with nick Scatman
Its Steve Pellegrini, he's on Facebook if you cant find him on here Marek.
http://www.deloreans.co.uk/forum/member....le&uid=928
