15 Feb 2018, 13:26
So I am trying to do some routine servicing on my D including new filters and oil.
As my main fuel filter does not appear to have been replaced in a few years I thought I would tackle that first.
It's in a hard-to-reach area and was stuck hard to the rigid fuel line but with a couple of attempts and skinned knuckles I was finally able to remove it, the bracket and finally unscrew the line coming out the top -Getting sprayed with a trickle of fuel at the same time!
Once out I re-used and fitted the bottom hard-line elbow and securing bracket, with new rubber strip to it to the new filter purchased from deloreango.
Re-fitting I connected the top hose with two new brass washers, replacing what was there before, loosely fitted the filter and bracket back to the frame and then with a bit of PTF tape around the bottom connector screwed in the hard line.
Now I have tried this 3 times, making everything as tight as possible, but when I start her up and check for drips I have fuel pissing out from the top and bottom connectors.
I managed to get the bottom one to almost completely stop but the top connector continues to leak. I've tried with a different combination of washers etc but still it leaks.
WHY IS THIS SO HARD!
Frustrated I tried today to do an oil change, something I have done before in the past. Unfortuenelty my oil drain plug must have got a bit mangled up the last time I did it and the tool I used before no longer fits. After trying to fashion various other tools to budge it I have had to give up. I have a new plug from deloreango that takes a simple spanner fitting but need to get this one out first.
So much for tackling the 'simple' service tasks.
Anyway, just wanted to vent. I will try again once the smell of petrol, oil and frustration goes away!
S
S
