Rear license plate bezel
Hi!
Its been a while since I posted.
I'm having trouble figuring out how to remove the rear license plate bezel (the after market aluminium one with no screw holes).
Any thoughts anyone?
#10646 is now in Australia by the way! Just need to put some local plates on and away we go! We had a full chassis restore before shipping it over as well, Courtesy of Martin G.
'82 Grey Interior, Manual VIN# 10646
'09 Audi A8 Quattro
If its one of James RG's ones for European-shape numberplates, the method is to remove the two rear light clusters and reach inside where you will find two nuts on each side of the bezel which are on studs which are part of the bezel and poke through the original holes in the fascia.
http://homepage.ntlworld.com/james.grant793/fitting.pdf
Should make it easier to understand
James
www.classicdelorean.com
Colchester - Essex - UK
So NI-US west coast - US East Coast-England-Australia ? A well travelled car Smile
Great, thanks everyone.
All registered and back on the road after a good clean! Has to replace seat belt buckles with Australian compliant ones but no other conversion required thankfully.
Its certainly been a hell of a Journey!
'09 Audi A8 Quattro
