Servicing Items and Part Numbers
How about we create a new section of the forum that has a nice simple all in one check list of items needed for servicing the car and crucially the part numbers?
I'll start with what I know in regard to the items that need checking/replacing but sure there must me more parts/items I've not covered:-
Servicing
Oil 10/40 semi synthetic – 6000 miles/annually Volume needed from empty ?
Oil Filter
brake fluid – change every two years?
Grease nipples on control arms for ball joints upper and lower
Dist Cap (every 12,000 miles?)
Rotor Arm (every 12,000 miles?)
Air filter
coolant – 50% mix? Which type/does it matter
clutch fluid (dot4 only) volume from empty required ?
spark plugs
fuel filter
brake pads – greenstuff
Belts
aircon belt
altnerator belt
aircon
R134a gas (amount required 950g?) Oil amount?
Orifice tube
Accumulator
check for play in balljoints
The above lacks the current part numbers. I know some of those previously published are no longer correct/current so any help with publishing those that are known to be current/correct would be great.
Sounds like a plan, perhaps create a 'sticky' in the engine section when all the info is sorted?
hi
there use to be a parts cross ref in the mag, and one or two sites had a long list of equivalents
icluding calipers etc
steve
Chris Hawes Wrote:Servicing
Oil 10/40 semi synthetic – Every 6 months regardless of mileage - 6 litres?
Oil Filter – Mahle OC460
Air filter – Mahle LX689
Grease upper and lower ball joints – Every 12 months
Distributer Cap – Intermotor 44030
Rotor Arm - Intermotor 47080s
Spark Plugs - Bosch HR6DC+
HT Leads - PFV902576 (Volvo 260/760 series B28 Ignition Lead set)
Fuel Filter – Bosch 0 450 905 401 every 10,000 miles or 2 years whichever comes first
Coolant 50/50 mix - Bluecol Antifreeze & Summer Coolant 5L 2 Year Protection – change every 2 years
Brake Fluid DOT 4 - Change every 2-3 years
Clutch Fluid DOT 4 – Change every 2-3 years
Brake Pads – EBC Greenstuff pads, rears DP2101, fronts DP2291
Brake Pads – EBC Redstuff pads, rears DP3101C, fronts DP3291C
Handbrake Pads – EBC Blackstuff DP709
Belts
A/C Drive Belt – Gates Auto Master 6234mc
Alternator Drive Belt - Gates Auto Master 6230mc
Fuel Accumulator - Bosch 0 438 170 029
Gearbox fluid - 75w90 Castrol Syntrans Transaxle (manual transmission/final drive) - Change every 3-5 years
Amended with comments/part numbers.
DOC 649
ex DOC 562
This is great, thank you for this information. Does any one know where to get the tool to remove the sump plug? Is it just a standard tool?
Mike
Bingley, West Yorkshire
VIN 2493
Sump plug key: http://www.ebay.co.uk/itm/151276697267
Manual transmission plug key: http://www.ebay.co.uk/itm/251559133995
DOC 649
ex DOC 562
Thanks mike Smile sump tool bought . Looks like someone beat me to the transmission one though Sad
Mike
VIN 2493
Sump-plug removal tool = cut down square bar from inside a door handle with a spanner on it! Smile
Thanks for the comprehensive list Mike.
I now have all the bits except for:-
Quote:HT Leads - PFV902576 (Volvo 260/760 series B28 Ignition Lead set)
None of the motor factors I went to recognised the above part number. Any more information available so I can help source the right set?
Which version of the B28 is the DeLorean as I think there were multiple variants of the B28???
B28 F DeLorean version of PRV (Someone did tell me the 'F' is for foreign) UK sold Volvos etc. have B28E ('E' for Europe)
Ignition leads are in the electrical parts section on the forum but here's the link again.
http://www.partsforvolvosonline.com/prod...ts_id=2576
Nick H
DOC 650
Jaguar X-Type
DeLorean DMC 12 Vin#2862
My other hobby...
http://www.lccuk.org.uk/
B28F I always thought was the Federal (ie US) version, and B28E was the European version.
Remember the DeLorean in US engine spec is lower hp then an equivalent Volvo 760 of the same era.
The slightly later 760's were B280E, I think they had a slightly different cylinder heads or summat, cant exactly
remember though, but I'm sure Martin will advise Smile
