Stainless Steel Door Pins (set of 4)
I am very pleased to bring to you all a new product. I have recently invested in a lathe and I have just completed the first set of door pins.
These are turned from 303 grade stainless steel and have a highly polished finish, these will really be noticed on your DMC! They are made to the later spec of door pin with the longer thread length.
These have been made with a domed & chamfered end to help guide the door catch and try and reduce the damage caused to the pin.
The price is £60 for a complete set of 4 + £4.50 UK P&P (Royal Mail 1st class recorded) or £8.90 (Royal Mail International Tracked & Signed). I could make the postage cheaper but there wont be any insurance should they go missing.
These are made to order so please allow a day or two to get a set completed before I can post out.
[Image: 20140618_185329616_iOS.jpg]
[Image: 20140618_185443431_iOS.jpg]
[Image: 20140618_185502807_iOS.jpg]
[Image: 20140618_185534872_iOS.jpg]
[Image: 20140618_185356121_iOS.jpg]
[Image: 20140615_165244685_iOS.jpg]
They look lovely!
Could you put we down foe a set of the door pins please Paul and two rad brackets.
Thanks Chris and Chris!
I'll start work on another set of pins ASAP plus the rad brackets.
They certainly look the goods!. So much better than my rusty looking ones. Very tempted if you take PayPal as I am in Australia
David
What's the corrosion resistance of 303 like? I had a stainless water pump pulley go rusty recently.
stunned_monkey Wrote:What's the corrosion resistance of 303 like? I had a stainless water pump pulley go rusty recently.
Similar corrosion resistance to 304 stainless. The only reason I used 303 was for the machinability of it over 304. 304 is can be very difficult to machine.
What was your pulley made from?
Here's the bumf from the supplier I use:
Corrosion and Oxidisation Resistance of 303
303 stainless Steel shows good corrosion and oxidisation resistance in mildly corrosive atmospheric environments. Its sulphide inclusions act as pit initiation sites meaning it provides a lot less resistance than 304.
Grade 303 should not be exposed to marine or other similar environments, to prevent rapid pitting corrosion.
EN 1.4305 303 stainless steel provides good oxidisation resistance in intermittent service to 760°C (1400°F) and continuous service to 870°C (1,598°F).
So less resistant than 304 but giving the location of this part on the car I don't think you should worry too much about it.
Hi Paul,
I presume the price included fitting and subsequent door re-alignment?
Hopefully I see you in Dorset with your spanners and a little mirror on a stick! Flashy will be so chuffed! :wink:
airfireman1 Wrote:They certainly look the goods!. So much better than my rusty looking ones. Very tempted if you take PayPal as I am in Australia
David
Yeah paypal is perfect. I've made a start on a couple more sets last night. Should be ready at weekend. I'll be in touch with payment details and postage cost soon.
Thankyou, sound great
David
I have 4 sets of pins complete but 3 are spoken for. One set up for grabs.
Chris P, I need to finish off the radiator brackets and then yours are good to go.
airfireman1, I've sent you a PM.
Thanks Paul, send me an email with total price to history@deloreans.co.uk and I'll pay by return.
Got the Pm and you have funds
Thanks
Paul,
was it you making the large plates that hold the petrol tank in? If so have you any in stock?
