19 Mar 2007, 03:02
I wonder if someone would be so kind as to assist me with a wire hook-up problem as I'm a little unsure.
(1) There is a red-banded white wire which the wiring diagram says goes to the starter solenoid but there seems to be no connection point for this wire. There is, however, two blue/yellow wires which clip into a single plug which plugs into a single wire coming from the back of the starter.
(2) The wiring diagram also states that a white/brown wire goes to the oil pressure gauge sender, but I don't seem to have a white/brown wire. I certainly have a white/yellow wire which connects to the rear of the alternator but no white/brown wire.
(3) Lastly, there is a black wire with a red band which branches-off the harness against the engine compartment bulkhead. Can someone please assisst with the connection point of this wire.
Might be easier if I could possibly be sent some digital pics of the wiring set-up behind the starter, alternator and the oil pressure gauge sender.
Please go to the 'Topics Section' of www.ozdelorean.com to see pics of the wires in question.
Thanking you in anticipation. Luscious.
