09 Mar 2007, 14:27
I recently changed the alternator belt, which involved removing the air-con belt. To make that easier I just took the bracket with the adjusting pulley off entirely. Unfortunately I lost one of the two bolts holding it on (stupid), and then I realised that it also, for some reason, holds on an important cap thing over a hole in the engine. Since I don't want all my engine oil flying out I replaced it with the one remaining bolt, and a wedge of wood at the other end to stop it moving.
Now I need to find another, but I really have no idea what the size of the bolt is, otherwise I'd just buy another from B&Q. Can anyone help me out here? All I know is that the size of the socket I used to remove it was 11mm.
While I'm at it -- what's the point of that cap thing anyway?
Rob Williams
DOC 475
VIN 17152
DOC 475
VIN 17152
