Well I have a few sets of the new type hose here and on pulling the hose from the bango on one of the CPR lines it came apart with very little effort.
I have Spoken to A1 Hydraulics,
http://www.a1hydraulics.co.uk/ , who produced them as well as the braided clutch line and brake lines that DMCL supplied and they dont understand both the pulsing problem or why SOME of them come apart. Im not blaming there workmanship as it is excellent just that they not make fuel hoses that often, there a hydraulic company at the end of the day. There Clutch and brake lines are very good
The problem was never really rectified as Stuart's car, Nigel's Right Hander and Arron's car all display slight hesitation on light throttle at about 2000 RPM, you could feel the pulsing. I know as I have driven all of these cars over long distances and not just around the block. The warmer the cars gets the worse the pulsing gets. Now all of these cars had complete hose sets on them, and the problem is more to do with the metering head to injector hoses.
Also the problem with the Delorean was never at idle it was under acceleration and if you replaced the hoses with OEM ones the problems went away, so I do blame the hoses. If it's not the hoses then can someone explain why you can feel them pulse when you hold them and why there is this problem ???
If you want ones that dont pulse however then braided or hard ones are the way to go IMHO.
P.S. I have spoken to A1 Hydraulics,
http://www.a1hydraulics.co.uk/ and they will supply directly to customers. There prices are very good too
