http://www.ebay.co.uk/itm/Racing-Style- ... 390wt_1397
Now I just need the Ebay Roof Rack to go with them, and my car will be complete! 8)
Threads: 1
That must be for those 1984 DeLoreans that I keep seeing on the Internet
Travis
Threads: 814
:roll: why :roll: mind I have a non working window, wonder if I can retrofit these??
Threads: 27
Quickly Rissy..buy them before the others do,these will make your car No1 Delorean in the UK....!!
Threads: 45
ha these always crop up when i search ebay for delorean religiously every day
along with roofracks and car matts
Threads: 9
dknight Wrote:ha these always crop up when i search ebay for delorean religiously every day
Are you looking for anything in particular?
I did see a large metal DMC dealer sign in Germany of all places that was quite tempting, but the seller cancelled the auction before I could bid on it.
Threads: 350
I'm with you Chris, I've got a non working window too :lol:
Threads: 96
Not the place for "fix its" I know, but besides the obvious fuse/motor connections, the windows on both sides of my car were tempremental... ie would wind down but not back up, not work at all etc... the cause? The plugs on the backs of the switches. And not between plug and switch.... between loom and plugs but internally in the plugs... its like the copper wire corroded around the crimped connections causing intermittent operation. Similar story with the mirrors. The looms wern't the strongest point! Needless to say mine now fine.
Hope you guys sort yours.... and i seen some spurious wheel trims for the dmc on ebay last week... for almost 500 quid... i want some! ;-)
Two more classics for your christmas lists
First a photoshopped exhaust tip,
http://www.ebay.com/itm/DMC-DeLorean-2- ... 27cbe670b9
and then some awesome teatrays to set on your floormats
http://www.ebay.com/itm/2Pcs-DMC-DeLore ... 5761549%26
