30 Sep 2012, 21:54
As mentioned in my 'new members' post, this vehicle is currently being rebuilt as a right-hand drive conversion by P J Grady Europe. It is a manual with a grey interior. I have taken the opportunity to replace some parts and generally try to address reliability issues I have seen on this forum and other DMC-12 online material. Here is the current list; I am happy to hear suggestions for anything else I should look at.
Radiator air dam
Two-tone grey seat covers
Low-current radiator fans w/metal cowling
Heavy duty fuse block with light-up (on blow) fuses.
140 Amp alternator
Replacement ground wire
SS coolant bottle w/brackets
Soft lift door/boot/engine bay struts
Clutch air bleeder
High power / low noise fuel pump
Headlight switch saver relay
Braided SS clutch line with clear coating
Braided SS brake lines set with clear coating
Braided SS fuel lines set with clear coating
All bulbs other than headlamps replaced with SMT LED modules from SuperBrightLEDs (followed this guide).
Air intake mesh screen (as suggested by Chris Hawes)
Front tower brace strut
'Wings-A-Loft' Central Locking unit w/ remote door open + engine start + trunk release
Battery cut off switch
SS water pump pulley set
SS engine cover grills w/logo (to be painted dark gloss grey)
SS rear bumper lettering (to be painted dark gloss grey)
SS radiator front rock screen (to be painted dark gloss grey)
SS negative sill logo
SS shifter knob w/pattern
Thin grey dealer side stripe
4x speakers replaced with Eclipse modern equivalents
Stereo replaced with modern car PC
I am also investigating the possibility of fitting the car with a twin-turbo engine based on the Legend pattern. This is a tricky proposition due to cost, reliability and installation difficulty; haven't managed to find a viable supplier yet, but still hopeful that DPI might be able to ship an appropriate engine to the UK. If so will take their recommendation on appropriate radiator, brake and suspension upgrades. Will probably do some trivial electronic stuff post-delivery e.g. subwoofer in cubbyhole, backup camera etc.
Radiator air dam
140 Amp alternator
Clutch air bleeder
![[Image: dash.jpg]](http://i36.photobucket.com/albums/e6/stargliderx/dash.jpg)
![[Image: front.jpg]](http://i36.photobucket.com/albums/e6/stargliderx/front.jpg)
![[Image: rear.jpg]](http://i36.photobucket.com/albums/e6/stargliderx/rear.jpg)
![[Image: roof.jpg]](http://i36.photobucket.com/albums/e6/stargliderx/roof.jpg)
SMT LED kits, shifter knob and 4 x Eclipse speakers also arrived, stainless parts from Julian at Just Bandits should be on the way.
