windscreen wipers stopped working
Fuse 3 (10 amp) Brian....
Module is located here...
http://deloreantech.wikia.com/wiki/Wind ... rol_Module
Hope this helps...
Ben
You can try to bypass the module by disconnecting both connectors and plugging them together.
You'll loose the interval function, but the wipers should wipe.
VIN 4500
