Recovering panels
I'm planning on recovering the panels that house the rear speakers. I've noticed that it's a vinyl material that appears to be quite thin and hard perhaps shaped by heat I'm not sure. Does anyone know if this is available anywhere?
I'd like not to do it in standard leather as the speaker hole need drilling out and I'm not sure if it would work in standard leather.
Mike
Mike Dargan
VIN #2311
DOC 697
mmm, not sure if you can get this give Dave howarth a ring I'm sure if any knows he will. Though I'm sure a good vehicle trimmer would be able to do a great job and punching the holes in would not be a problem (but time consuming). Failing that cover them and put decent speakers in the back panel below the window.
I dont know if Dave has those panels because Phill needs one (or both) for
Sorbet as his are cracked, and we've asked about them before.
A vehicle trimmer will be able to recover in leather or vinyl tho, and the end
result will last longer then a replacement OEM panel that is already 30yrs old
I would have thought.
