Changing main crankshaft oil seal (transmission end!)
Quick question – does anyone know if you have to drain the oil before you change the main crankshaft oil seal? Ie, is the normal oil level above this point?
Ta!
R
Just to post this bit for posterity: Oil level is below the seal, i.e. you don't need to drain the oil to change the seal...
Which is of size: I.D. 80mm O.D. 100mm Depth 13mm
