06 Jul 2010, 20:49
Track rod end information
There are a lot of x/refs going around for the track rod ends but not all track rod ends are equal.
The trouble stems from the length, if it is too long it will not allow enough toe in adjustment when
on the car, you will simply run out of thread.
I had been warned that there can be variations, so I ordered a set from Dave Howarth to be sent
with the steering rack which I was having refurbished. Sure enough they have turned up and they
are longer than the originals.
The photo of the OEM track rod fitted on the rack is in the position it was at when on my car so
it is fair to suggest that it is somewhere near the correct position, from the 2 photos you can clearly
see that if I were to install Dave H’s track rod end I would not be able to fit the retaining nut behind it.
Whilst the nut could be turned down, the track rod end could be cut shorter, these are effectively
treating the symptoms not addressing the problem.
I’m going to return mine to Dave H and try and source some alternatives that are the correct length.
I don’t want to fork out for a 4-wheel alignment only to find they isn’t enough adjustment to achieve
the correct setting.
Does somone have a 100% cross ref for these or a source, I'd rather do the job once and do it right!
Thanks
James RG
Thanks
James RG
www.classicdelorean.com
Colchester - Essex - UK
