20 Aug 2009, 00:12
Has anyone got instructions for fitting one? its the split one i got from ed
Thanks
John
Thanks
John
SCEDT26T9BD005902
steering column bushing
20 Aug 2009, 00:12
Thanks John
SCEDT26T9BD005902
20 Aug 2009, 19:00
They can be particular so and so's to fit, and will sometimes require a certain amount of
grease, then a degree of brute force and ignorance to get in place . I'm not familiar with Ed's split ones tho........
Jul 1981 DeLorean - Flopsy #2292 Aug 1989 Cavalier 1.6L - Guinney Apr 2021 Mokka-e Launch Edition - Evie #170
28 Aug 2009, 11:08
Ed's split ones are a standard one with a cut though it so in theory you can fit them without removing the column, although from what I've read, the amount of effort involved with avoiding removing the column, you might as well just do it the easy way and remove the column...
28 Aug 2009, 13:41
I had a split one which I tried and failed to fit properly.
As far as I can tell, in theory you just need to hack the old bushing out and then bugger the new one into place with a screwdriver or something. That's what I tried but I didn't get it in properly and it popped out. Ended up removing the column and fitting a normal one, but I'm sure that's not necessary if you're less of a klutz than me. You can read about my inept efforts here: http://www.deloreaneurotec.co.uk/forum/v...f=20&t=223
VIN 7176
DOC 643
01 Sep 2009, 14:57
I got one of the Delrin ones from somewhere and fitted it by remiving the comun, WD40-ing the bush and surroundings, and hitting it with a hammer using an appropriate sized socket as a 'drift, and in it popped. Obviously you couldn't do that if the column was going through the centre of it, unless you could make a C-shaped punch to fit round it to do the same. WD definitely helps though....
Derbyshire DOC 393 1981 DMC-12 VIN 06126 |
« Next Oldest | Next Newest »
