14 Apr 2009, 12:26
This weekend was my first real chance to drive the D properly. 600 miles and I'm just about getting used to it!
I've got a few questions though for those of you who've had their cars longer and done certain things to them. Basically I'm trying to ascertain how much of the D's bad handling is intrinsic, and how much of it might be due to certain things I can improve.
At the moment my car has Spax shocks on the front (out of box settings, havent had a chance to check the clicks), euro height front springs and front strut brace, but the rear shocks are still stock (Spax yet to be fitted).
Two main areas of the handling trouble me. There's a fair amount of play about the straight ahead on the steering. Perhaps 45 minutes worth on a 12 hour clock, if that makes sense. How normal is this? Is this the same for those of you who've had their steering racks refurbished?
The car wanders around on the motorway - particularly at 70+ mph. This may be partially due to the play on the steering making small adjustments difficult, but have other people noticed this too? It's pretty demanding keeping the car straight down the middle of the lane without drifting off one way or the other.
The second area is the handling when driven enthusiastically. In North Wales where my Mum lives there are some excellent A roads where you can get a chance to drive the car the way it was meant to be driven. However, the car is really quite edgy at times. Under hard power out of corners it doesn't like holding a line, and through sweeping bends it yaws and pitches all over the place. Again the play on the steering won't help here as it makes it more difficult to get the car 'set', but I would expect it to be better than it was.
So it strikes me there are a few possible things that are going on here:
a) Trailing arm bushes are fudged
b) Stock shocks on rear really not helping
c) Other bushes (ARB, LCA) are fudged (although Chris didnt think they were too bad)
d) The DeLorean really does handle this badly
Any thoughts? If this is as good as it gets, then that's fine - but no point leaving it like this if it can be helped!
VIN 7176
DOC 643
DOC 643
