Threads: 96
Got round to putting these on today, and I must say highly recommended.
I've had them nearly 12 months, and only just got round to fitting them......
The results :
Excuse the overly sized Fog light LED, unfortunately fitting this without a huge grommet proved impossible
These can be purchased from James at :
http://www.newoldbits.co.uk/
Ben
Threads: 21
James, where did you get your stainless shift plate from? Cheers!
VIN 7176
DOC 643
Threads: 79
Hi Ben, my car has the fog light decal on the switch but the tell-tale light is wired to the Lamda light on the dash so it looks stock.
Threads: 96
Hi jerzybondov
I'm Ben, not James...... thats the name of the guy you get the decals from!
My polished gearknob and shifter plate came from DMOCO at the following link....
http://www.dmoco.com/products.html
Costs about £250 for both, a doddle to fit, but the quality of the rubber boot they supply for the underside of the plate is pants. Mine split on fitting, and has got worse since.....
Hardly noticable though!
Ben
Threads: 21
Hi Ben, Sorry for the mistaken identity, wasn't paying enough attention. Thanks for the info on the shift gate!
VIN 7176
DOC 643
Threads: 96
Dan1986 Wrote:Hi Ben, my car has the fog light decal on the switch but the tell-tale light is wired to the Lamda light on the dash so it looks stock.
Thats probably the best way Dan. Unfortunately though, my car still has the lambda counter etc, so its best left alone. I suppose it could serve dual purpose, but this way seemed far easier.....
Threads: 79
Hi Ben, the lamda light can work for both the lamda counter and the fog, as mine did. I have removed the lamda counter all together now and put in one long speedo cable so its less strain on the angle drive.
Threads: 56
Ben,
Thanks for the feedback....
I will be bringing a load of these sticker sets to Calley hall this weekend if anyone requires a set, they cost a little more to produce this time (selling @ £9 per set free P&P) but I will do a bit of a discount at Calley Hall since I won't have to use and envelope + postage, it all adds up!
James
TheOriginalMrP Wrote:Got round to putting these on today, and I must say highly recommended.
The results :
Ben
Threads: 56
Ben,
James RG
The results :
Ben
Hi James
I will take a set ...if only so people know how to get out of my car
Mike
Threads: 69
hi
the fog, you can just about drill and fit a small led, with legs cut off to fine wire without a grommet at all.
then a small dab of glue under to hold in.
that what i did originally on mine.
Threads: 96
That was the intention........ but the LED's i bought had holders which needed quite a large hole drilled, and when fitted, the holder was fine - but the LED kept moving up and down the holder. Glue wasnt an option as I only had superglue, and didn't want any "blooming" on the black plastic. Then I ended up with a hole too big in the switch, so its staying as it is now! It's raised nature also means it don't get missed if you knock it on with your elbow by accident changing gear.......Ben
PS James, i have not got the lock/unlock decals, so how much do you want for a pair for each door, and another fog light decal?
Cheers.
Ben
Threads: 23
bozzzydmc Wrote:Hi James
Mike
Yeah, would have stopped Keeley Hawes from giving your headliner all that grief! :lol:
Best regards
Carl & Alex Hammond
DOC361
VIN#11777 (don't ask!!)
Norfolk
Threads: 3
Hi James,
Do you do a sticker for the headlight button?
Aaron May
DOC: 573
VIN: 16723 - the LPG delorean
1999 Corsa 1.2L GLS Auto
The Wii-Master!
Threads: 79
The headlight sticker is transparent so the light shines through so probably one for houston.
