rear quarter fixing lower bracket and valance.
at the bottom rear of the rear quarters there's a bracket that screws to the body and screws to the fender and the small plastic valance.
can someone tell me how this goes?
does the lip on the rear fender fix behind the bracket (in between the body and the bracket) or does it sit ontop of the bracket (so it goes fender lip-bracket-body?)
Can't work it out. I think that maybe it's the latter because of the screw holes on the fender, but i need to make sure.
this page:
http://www.delorean.com/store/c-307-8-3 ... panel.aspx
the fender and item 15.
thanks
Dave.
Hi Dave,
Bracket fixes to car first, then fender/rear quarter goes over the bracket so that the small bolts screw up through the fender and into the bracket.
The black plastic valance fits last, covering these bolt heads.
So starting from top to bottom.
Bracket
Fender lip
bolts
valance.
Best regards
D
VIN 4532
DOC-574
yeah, though that. because the fender wouldn't be fixed if the bracket and fender were the other way around.
thanks
Dave.
